It is currently Mon Oct 19, 2026 11:20 am
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Feb 07, 2017 8:05 am
Hi Folks,
Anyone like to recommend (or not) a cheapih double din GPS for the Jimny 2010??
I realise the standard dash is a "one of" but I will modify or replace if necessary.
thanks
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Post Posted: Tue Feb 07, 2017 12:03 pm
Can't help you with head units but there are double din fascias available from Suzuki.
Vehicle: 91 Tin Top
Post Posted: Tue Feb 07, 2017 3:26 pm
Taken from my build thread;
pete_79 wrote:
I did the most important Jimny upgrade this weekend.
Installed a decent sound system....
Picked up a (hardly) used Chinese Jimny head unit and some new speakers.
That head unit is the easiest change over I've ever done, unscrew and unclip the stock one, screw and clip the new back in and your done.
Needed a bit of trimming to squeeze the 6" speakers in the back, but worth the effort.
It's far from a thumping sound system, but 1000 times better then the stock unit.
boeman wrote:
*edit;
Just noticed that eBay link has expired, the new one is different. The one I installed had iGo primo GPS and was great off road as well as on road. DVDs worked well, never used the remote though. ;)
Users browsing this forum: No registered users and 186 guests
