It is currently Tue Oct 06, 2026 10:18 am
Post Posted: Mon Jun 29, 2009 6:01 pm
Hi All,
Does anyone know which VRS kit is the right one for my motor.
As per my rego papers my 93 WT has a G13BA 1298cc motor.
I can only find the following info on the subject
DN480 - VRS Kit for G13A motors
DN481 - VRS kit for G13B motors
Which one is the right one for the G13BA SOHC motor ?
Any help would be much appreciated.
Cheers,
Daniel
Vehicle: WR250F/Jeep XJ
Post Posted: Mon Jun 29, 2009 6:39 pm
Check what is stamped on the block.
You might find that the g13b is the dohc swift gti engine.
When I rebuilt mine I got the VRS DN480 kit. It had the wrong ring size. I checked my block and it was a g13ba block.
My mate went and changed the rings which were the only difference....
AFAIK the G13A were 1324cc not 1298cc. Are you confused yet? I am :?
Post Posted: Mon Jun 29, 2009 7:47 pm
Permaseal list DN481 for both engines, ACL may list something different
Post Posted: Mon Jun 29, 2009 9:36 pm
If your kit had rings in it... It wasn't a VRS set...
VRS stands for Valve Regrind Set and is all gaskets/seals from head gasket up.. No rings.. No bearings.
Vehicle: 92 Suzuki Sierra
Post Posted: Tue Jun 30, 2009 2:29 am
i got a sealed vrs kit here, says DN480/1mt
suzuki G13A:G13B
itsa monotorque/ACL brand
forget the blocks, they are easy to diferentiate
if you want tricky, have you noticed the heads have S-'x' cast in them on th intake side
i got two heads with S-5, one i definetely know was off a g13a sierra, the other may of come from a sierra
i got one head with S-2 which came off a vitara
and finally a S-6 which came off a carby g13ba swift motor which has a factory block off for the mechanical fuel pump ?????
i can only hazard that its a series thing so i would love to find out te difference between all the 1.3l head (1.3l vs 1.6l is obvious and its not just the exhaust valves)
Post Posted: Tue Jun 30, 2009 4:56 am
Thanks for clearing that Up Santos, i thought we may have got the rings and bearings seperate when we were rebuilding my motor. As I said everything in the 480 kit worked on my head.
Users browsing this forum: No registered users and 140 guests
