It is currently Tue Oct 06, 2026 10:18 am
Post Posted: Tue Jun 30, 2009 3:06 am
hey royce, or others that have an opinion, my auto choke is not working and seems to be using more fuel atm
can the auto choke not working affect the fuel consumption
and i did a search and found this comment made by Royce, should i follow this advice and problem solved?
cheers
Cade
ok to set the choke
with engine cold and the intake hat off, the flap should be closed, look at the little gear type linkage on the side that actuates it and you will see 2 lines, they should line up, if not the tension is wrong, to set that look round the back/side of the carb where the water hoses connect and you will see a screw sticking out of a cylindrical chamber, turn that till they line up, now the amount of choke and time it stays on should be right
next the fast idle speed, have a good look at the throttle linkage and down out of the way youll see a screw you cant get at unless you are holding the throttle full open, thats the fast idle, to set hold the throttle open and screw it in a bit, let it go and start it up and see, I guess you want 1000-1200 rpm.
should be all good then, before doing this when the engine is up to temp check both water hoses into the carb are hot, otherwise there is a blockage and the choke will never turn off
Post Posted: Tue Jun 30, 2009 3:11 am
if it just stopped working 1st check the coolant is full, the thermostat is fitted and working and both water hoses to the carb are getting hot
Post Posted: Tue Jun 30, 2009 3:25 am
coolant is full, thermostat was replaced only in february
i will check the hoses in the morning cheers
Post Posted: Tue Jun 30, 2009 11:16 am
If that all works out, make sure there is no blockage in the cooling ports on the carby
Users browsing this forum: No registered users and 153 guests
