It is currently Sat Sep 26, 2026 11:10 am
Post Posted: Thu Dec 02, 2010 7:21 am
I'v got a Drover that has a 1600 EFI Vitara eng fitted. The dash in it is the one that dosen't have a factory tacho & mate has given me an after market tacho to mount on top of the dash. The trouble is I don't know wich wire to tap into. There is a plug in the side of the distributor that has 7 wires coming out of it, can anyone tell me wich is the one I need for the tacho?
Cheers.
Post Posted: Thu Dec 02, 2010 7:34 am
Signal wire goes to negative on the coil.
Post Posted: Thu Dec 02, 2010 7:57 am
Just had a look under the bonet, I can't see anything that looks like a coil. On my last suzi the coil was mounted on the fire wall, but that was a 1300 carby eng this is a 1600 EFI. What should the coil on an EFI look like & where is it on the motor or the body?. Sorry if this question sounds stupid but I have never had a EFI eng before.
Post Posted: Thu Dec 02, 2010 9:40 am
The brown wire coming off the noise filter should be tacho, it is on all the other vit eng's.
The noise filter is a lil black thing in the harness that look's like it does nothing, should be near the dizzy plug..
Should be!!!
Post Posted: Fri Dec 03, 2010 3:28 am
Thanks Steak_knife,
Is this it? I know it's not black but it's the only thing I could find with brown wires coming out of it.
Post Posted: Fri Dec 03, 2010 3:55 am
taco is a food...................tacho is the car bit.
Post Posted: Fri Dec 03, 2010 5:02 am
Yep... Your right I should a stayed at skool longa.....lol
I'll try and fix it up.
Vehicle: LJ80
Post Posted: Fri Dec 03, 2010 6:07 am
and so yoo shood
Post Posted: Fri Dec 03, 2010 6:40 am
:lol:
That is a noise suppressor, but not the one needed, you need the one that's in the eng loom, that one there in in the original loom.
Post Posted: Fri Dec 03, 2010 7:20 am
Iv'e had a real good look around the loom but stuffed if I can see it. I might just have to run it down to the local auto elec & get them to hook it up, I was hoping to do it my self. You get a certian sadifaction having a go at somthing you dont normaly do.
Thanks for the help Steak_knife.
Post Posted: Fri Dec 03, 2010 7:28 am
89tintop's an auto lecky down Gc way, Pm him & have a chat..
Post Posted: Fri Dec 03, 2010 8:44 am
PM sent.... see how I go...
Cheers.
Post Posted: Sat Dec 11, 2010 7:14 am
For anyone who may need this info in the future, its the brown & white wire.
It is the second wire from the left on the plug to the distributor .
Cheers, thanks to 89 tintop for all his help.
Users browsing this forum: Brenno, Google [Bot] and 239 guests
