It is currently Sun Nov 15, 2026 12:30 am
Post Posted: Wed Jul 08, 2009 1:55 am
hi there just wondering if someone could tell me how to adjust a new suzuki sierra clutch cable from scratch.thanks
Post Posted: Wed Jul 08, 2009 11:35 am
put it in, do the nut up till you still have a bit of free play in the clutch arm and your set :)
Post Posted: Wed Jul 08, 2009 10:28 pm
Go to http://neh-tech.com. Look up Fixit files. Heaps of Zuki stuff there inc. exactly what you're after. Cheers.
Post Posted: Mon Oct 26, 2009 5:59 pm
yer ive gotta tighten my clutch to im just to lazy to do it at the moment
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Mon Oct 26, 2009 6:08 pm
I want to do this, but the link no work.
Mine does burn a bit when extreme playing.
Post Posted: Mon Oct 26, 2009 11:18 pm
when you fit the new cable , do the adjuster nut up until about 5mm of thread is hanging out past the adjuster nut , you then adjust the 2 nuts at the bracket on the block so that when you apply pressure with your finger on the clutch pedal , you can push the pedal down 20-25mm before you feel any resistance . This is called pedal freeplay.
If you dont have any pedal freeplay , the throwout bearing will be resting against the pressure plate constantly spinning , this is not good , in extreme cases of being too tight , the throwout bearing will be semi disengaging the clutch and will cause the clutch to slip.
too much pedal freeplay will cause the clutch to engage very low (and cause hard selecting of gears and/or crunching), not enough freeplay will cause it to engage high.
as long as you have some pedal freeplay , you can virtually adjust to where you feel comfortable with it engaging.
if you have correct freeplay (20-25mm), and the clutch doesnt disengage fully , you could have a worn clutch , or other issues
does all this make sense ?
Post Posted: Mon Oct 26, 2009 11:22 pm
8O that may be the driver.
Post Posted: Mon Oct 26, 2009 11:28 pm
Oh yes, absolutely.
Playing is fun, but only when done to extremes.
hehe.
Post Posted: Mon Oct 26, 2009 11:43 pm
SuziBlu wrote:
Oh yes, absolutely.
hehe.
Is there another way?
If only I could get paid for playing. :P Gota be dirty.
Users browsing this forum: No registered users and 69 guests
