It is currently Sun Jun 24, 2018 7:03 pm
Vehicle: 1996 X90, 2017 Vitara S-Turbo
Post Posted: Sun Dec 03, 2017 12:54 pm
Inherited my Daughters X90 with stuffed balancer failure which had damaged the oil pump casing and flogged out the key way on the crank
Just for convenience I'm chucking that engine and going to just drop in a replacement
So the question is. Will a G16B from a Vitara bold straight in?
Is there any differences at all, such has manifolds, Distributor etc.
Also any other model G16B engines bolt up. Baleno etc??
It's gonna be my old getabout shitter
It's got really crappy blue/purple faded paint
Might buy a bunch of cans of satin black paint and really make it look crap
Post Posted: Sun Dec 03, 2017 2:08 pm
All G16B's basically have the same block and head. IIRC the X-90 uses the later style of G16B with the smaller AFM and some other small differences. Any vitara G16B will swap in but you might/should need to swap inlet manifold and distributor to reuse the X-90 injection/AFM etc.
hillbilly 2 wrote:
Gwagensteve is why auszookers will never be taken seriously
Vehicle: LJ50V 2 stroke
Post Posted: Sun Dec 03, 2017 3:29 pm
I would throw new main bearings in it as well.
if it damaged the oil pump casing, the crank was most likely thrashing around as well. you'd be surprised how much crank will flex!
ive seen balancers fail and they usually kill the centre main bearing instantly.
Vehicle: 1987 WT LWB Sierra
Post Posted: Mon Dec 04, 2017 10:35 pm
But he's replacing the entire engine for a new one... so any wear from the balancer failure would be completely irrelevant seeing as he's not even using that engine anymore?
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot] and 9 guests
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC + 10 hours
