It is currently Fri May 25, 2018 5:20 am
Vehicle: Suzuki Sierra SJ80
Post Posted: Wed Dec 13, 2017 7:30 pm
I've had this problem since buying the car; when going over bumps and uneven road surfaces I can feel and hear a clunking noise (you can also hear the movement/ vibration when idling at 900rpm, seems to be the sweet spot). I've found it's coming from the steering shaft/ column as I'm able to replicate the noise when wiggling the steering shaft up and down. The most play (up and down) seems to be basically at the firewall and it is definitely not the uni joint on the shaft. Also when I push up on the steering wheel when going over bumps it doesn't make any noise.
Any ideas? ThankS!!
Post Posted: Sat Dec 16, 2017 5:12 am
Bearing or bush died in the upper column. Never had to replace one. Either get a second hand column and swap the key barrel over or console the manual
Post Posted: Sat Dec 16, 2017 6:18 am
Have you checked it's not a loose tierod
Phuck Photobucket
Post Posted: Sat Dec 16, 2017 9:43 pm
No it's definitely the steering column/ shaft. There's no play in any other components. Do you know where the bush is located (closer to firewall or steering wheel)?
Users browsing this forum: Google Adsense [Bot] and 5 guests
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC + 10 hours
