Vehicle: sierra
Posted: Sat May 12, 2018 3:08 pm
Ok run down
Brought 1995 g13ba Suzuki serria of a guy Was running rough he said he was told needs carbi rebuilt
So I’ve have it nearly 2 years now
I’ve done the follow
- attional earths - unplugged all sensors clean up and put back in - new coil - carbi rebuild - new Flexi line and clamps on fuel side - new fuel filter - new leads - new plugs - new rotor button - replaced head gasket - new fuel pump
And in addition I think if check all and every other item
Car runs sweet but cuts out, can’t find reason starts again no worries and drives away
Feel it’s temp related because when it’s cold it runs longer. More I drive it the more often it cuts out
Honistly feel I’ve check every thing and replaced every thing possible but still no idea
Does it cough, splutter and fluff out or is it just like someone has turned the key off? Does it do it under specific circumstances (eg idling) or is there no pattern?
Dying ignition module Blocked pickup in fuel tank Blocked fuel tank breather
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 18 guests
