Gday I am about to change drive and alternator belts in a early 2012 auto Jimny and will probably have to top the transmission oil up after i take the radiator out. The owners manual and service manual states that I should use suzukiATF 3317, or Mobil ATF 3309 or equivalent to Dexron 111 oil. The quickest way to get replacement oil for me is at the local Supercheap , however none of the Dexron 111 or other oils such as Chief, Penrite, Nulon , Castrol etc actually mention Suzuki on their data. Has anyone on the air any advice on topping up, dont want stuff it up obviously. I can get mobil atf3309 online but it will take a few days. Thanks.
I've always used the Castrol one but any are fine if they are Dexron III compatible. Might be worth dropping the pan and changing the filter also depending on when it was last done.
Fluid level is usually checked with car running and in the transmission park at operating temperature. I doubt you will lose much at all taking the radiator out.
If you've got the radiator out I'd recommend installing a separate cooler and bypassing the one in the radiator, as well as fitting a gauge as per steve's suggestion.
Users browsing this forum: No registered users and 191 guests
