http://auszookers.com/forum/
Passanger window switch vitara
http://auszookers.com/forum/viewtopic.php?f=5&t=55231
Author:  Cabbage2000 [ Fri Jun 08, 2018 12:11 pm ]
Post subject:  Passanger window switch vitara
Hi ive got a 1991 suzuki vitara with power windows and cant figure out how to get the switch out of the passenger side as it dosent work can anyone help me on this? Ive already traced the problem to the switch just need to get it out to replace it do i need to remove the entire door panel?
Author:  fordem [ Fri Jun 08, 2018 10:48 pm ]
Post subject:  Re: Passanger window switch vitara
The switch "snaps" in from the top - if you're replacing it, you can just pry it out using a broad bladed knife, something like a drywall or putty knife - this will typically damage the clips that hold the switch but not the door panel.
Out of curiosity - how can you have "traced the problem to the switch" without either removing the switch or the door panel?
Author:  Cabbage2000 [ Sun Jun 10, 2018 10:02 am ]
Had an auto sparky i know as a mate have a look at it and he told me it was definetly the switch but has never worked on suzuki vitaras before and couldng figure it out, thanks
Author:  atari4x4 [ Sun Jun 10, 2018 3:33 pm ]
tried the diy fix yet?
viewtopic.php?f=17&t=24623
Author:  Cabbage2000 [ Sun Jun 10, 2018 8:06 pm ]
Mine looks different to those switches ive seen them before on other vitaras but the one i currently own is a different switch ill post photos when i can...im not hating on anything the reason i posted this in the first place was to find help because yes i dont understand which is why i asked for help in the first place
Author:  atari4x4 [ Tue Jun 19, 2018 3:50 pm ]
yes the switches will be slightly different, but the same theory applies.
Author:  fordem [ Wed Jun 20, 2018 8:28 am ]
Don't let Atari's signature get to you - it's not directed at you ...
Author:  atari4x4 [ Wed Jun 20, 2018 8:36 am ]
lol it's an oldie but a goodie. #twiggy
