Joined: Thu Mar 29, 2012 4:21 pm Posts: 106 Location: Melb west side
Vehicle: Suzuki Jimny
Posted: Thu Jun 14, 2018 8:05 pm
Hi just purchased a Suzuki Sierra wt I’m new to this and this is my first Sierra What’s the best/cheap way to lift the Sierra and that has good flex too Pictures of people setup would be great. The Sierra dose have a front bull bar
Suspension lift increases compression travel at the expense of droop. Increased compression travel can allow faster progress across rough terrain due to reduced suspension bottoming. However, the increased spring rate required to maintain a higher ride height generally worsens ride and often prevents the axle from reaching the bumpstop, which is why there’s a net loss of travel once a lift is installed. (Also many aftermarket shocks have less travel than standard)
If you are lifting for cosmetics or to fit a larger tyre, a body lift is a way to achieve this without the suspension compromises.
The trend now is towards minimal lift, as we’ve learned that lift doesn’t really make the car work better.
Users browsing this forum: No registered users and 183 guests
