It is currently Sat Oct 03, 2026 11:07 am
Vehicle: buying
Post Posted: Mon Jul 02, 2018 7:17 pm
Hi I currently have 31's on my auzuki aierra wt, and at 100 I am at 3200 rpm
Vehicle: 1987 WT LWB Sierra Styleside
Post Posted: Mon Jul 02, 2018 9:43 pm
I've just plugged some values into the gearing calculator, and I reckon you're standard.
http://www.zuk-n-ovations.com/gear_calc.html
If:
A leafy 1.3 transfer in high range is 1.409,
1.3 leafy diffs are 3.727,
Wt 5th gear (should be, but depends on year) is 0.864,
Tyres are 31" tall, then
At 3200RPM you're traveling 65mph or 102kph. So that's pretty much what you've got:
A 0.864 fifth gear (and by association, a 1298cc motor (vs 1324cc)), stock 1.3 leaf transfer, stock diff gears and 31s.
Hope that helps :peaceout:
Post Posted: Mon Jul 02, 2018 10:41 pm
I’ve got 3038 in 5th (assuming sj70 5th gear), WT diffs and standard 1.3 transfer.
3428 for same as about but a 1ltr transfer case.
You’re close to being bang in the middle. But there could be differences I tyre circumference, I’d suggest Technotron is correct, your on stock gearing.
Edit: is your 100kph by the speedo or gps?
Vehicle: buying
Post Posted: Tue Jul 03, 2018 6:51 am
Thanks for the reply. It's by the speedo
Post Posted: Tue Jul 03, 2018 7:20 am
Speedo doesn't change with transfer gearing changes. My old LWB was nearly 30% out. Check again with a gps and see what revs you have,
I found it easier to just put a speedo app on my phone and use it.
Post Posted: Tue Jul 03, 2018 9:09 am
With 31” tyres your speedo will be out by around 11% give it take? So when your speedo is telling you 100kph you’d actually be doing closer to 111kph.
So you’d almost certainly be running stock gearing.
Post Posted: Tue Jul 03, 2018 10:09 am
17% so 117km/h
Post Posted: Tue Jul 03, 2018 11:38 am
If you need to ask, no you don't have reduction gears
Post Posted: Tue Jul 03, 2018 4:37 pm
17% so 117km/h
Ah thank you!! Was just going by memory after night shift.. not a greatly reliable source
Users browsing this forum: Purv and 155 guests
