Hi, I’ve noticed the hose from the brake booster to the manifold is a bit ratty and wanting to replace, does this hose have a check valve inside it and what sort of hose should I use ? (Car is sj80 1.3l) Thanks
They aren't in the booster on an SJ80 as I remember vacuum being present when pulling the hose off the booster. I can't remember if the valve is in the hose though like on a Vitara.
Users browsing this forum: No registered users and 165 guests
