It is currently Fri Oct 09, 2026 10:26 am
Post Posted: Fri Jul 20, 2018 1:38 pm
Hi all; knowing that the aw4 is shared across jeeps and toyotas, is there an option for a shift kit in the suzuki i.e. you just use a toyota or jeep kit?
thanks for any input, a search of part numbers hasn't led me to an answer, i just know they share some/most internals...
Online
Post Posted: Fri Jul 20, 2018 2:22 pm
What do you want the transmission to do differently?
Online
Post Posted: Fri Jul 20, 2018 2:24 pm
And to be clear, AW-4 variants/architecture are shared. Toyota make their own versions, for example. They’re not all interchangeable.
Post Posted: Fri Jul 20, 2018 10:46 pm
Chasing some firmer shifts. I've had stage 1 and and 2 kits in gm autos, noticeable difference in characteristics between the two. Just want to see if anyone has info.
Post Posted: Fri Jul 20, 2018 11:00 pm
What exactly do you mean by "firmer shifts" ?
Dr Suzuki - South east Queenslands most experienced mobile Suzuki mechanic.
Please like and share my facebook page - www.facebook.com/suzukimechanic
Online
Post Posted: Sat Jul 21, 2018 10:59 am
I assume dude! wants that high line pressure "snappy" shift feel. Which, if I'm right is a byproduct of higher line pressure used to hold the bands harder. It's not an end in itself.
Personally, I'd imagine offroad, harsh shifts would promote loss of traction.
Online
Post Posted: Sat Jul 21, 2018 11:19 am
dude!
Is the transmission flaring between shifts?
Is it slipping under load?
There's plenty of upgraded valve bodies for XJ AW-4's but some brief research has shown parts between the Vitara AW-4 and the Jeep AW-4 are not 100% interchangeable, so the VB's might not be. Plenty of XJ owners add power and their cars are very heavy. In the suzuki application the transmission is incredibly unstressed.
Post Posted: Sat Jul 21, 2018 12:18 pm
No flaring when shifting. They're just slow soft shifts. I plan on getting a trailer at some point for camping. Typically a basic "shift kit" adds to longevity when towing. Plus I've only noticed an increase in driveability with upgraded autos.
Online
Post Posted: Sat Jul 21, 2018 1:21 pm
An AW-4's outlast vitaras comfortably. They're massive overkill for a 1.6. I'd put a temp gauge and external cooler on it and forget about it, but if you really want increased shift speed, enquire with the XJ Cherokee shift kit vendors to see if anyone has used one on a Suzuki AW-4. I have a feeling the VB will be different though.
I have no complaints with the speed mine shifts, but I accept its under lighter load than in a Vitara which will speed up the shift.
Vehicle: vits
Post Posted: Thu Jul 26, 2018 12:23 pm
MV automatics in Adelaide do a shift kit for the Vitara AW4.
Post Posted: Fri Jul 27, 2018 11:23 am
You can buy shift kits for them. or you can run spacers in the collectors that do the same thing.
However the easy way to get a firmer shift, is to pull the Kickdown cable out and clamp it which increases line pressure for all shifts.
Users browsing this forum: No registered users and 255 guests
