It is currently Tue Oct 13, 2026 10:31 am
Vehicle: buying
Post Posted: Tue Aug 14, 2018 7:59 am
Gearstick in 1990 Suzuki aierra wont go into 1st or 2nd. Goes into 3rd, 4th, 5th and reverse fine.
There is no grinding of gears at all?
Any help
Post Posted: Wed Aug 15, 2018 6:42 am
Have you checked the shift bush and gearstick locator bolt? These are often a contender for problems and a good place to start looking.
The shift bush can break down over time and the bolt can snap. Give that a go and report back
Vehicle: buying
Post Posted: Wed Aug 15, 2018 7:39 am
Hi,
Yeah I checked the bush etc and that's all fine. I cannot move the 1st/2nd selector finger even with a screws driver.
Thinking finding a new gearbox?
Post Posted: Wed Aug 15, 2018 4:21 pm
Yeah ok.
Could be a few things but try pulling the rear extension housing off and checking if it’s them being restricted. They can burr in spots or perhaps something’s stopping a detent ball from shifting. Off memory first and second run off a single selector rod.
Hop on the LROR website and download the instructions for overhauling a gearbox. I’d be pulling the whole gearbox out and tackle it on the bench. You might not need to pull the whole gearbox apart but choose the sections of the instructions that gives you step by step guide to dismantling in re-assembly of the part you want to check.
Vehicle: buying
Post Posted: Sat Aug 18, 2018 4:46 pm
Thanks for the help.
Pulled the gearbox out and apart. Turns out the detent pin for neutral in the 3/4 selector had broken and was jamming the 1/2nd selector. Made a part to suit and put it all back together. And problem is fixed!
Post Posted: Sat Aug 18, 2018 6:04 pm
Ah brilliant!! Glad you got it sorted :)
Users browsing this forum: No registered users and 202 guests
