It is currently Wed Oct 14, 2026 5:42 pm
Vehicle: MY13 2.4 SWB GV (02 Paj Io)
Post Posted: Mon Aug 20, 2018 7:19 pm
Hi -
Has anyone removed the front skirt off the 2005-> Grand Vitara's?
Any tips and tricks?
I started this evening however looks like i will need to fabricate some filler supports to connect the wheel wells to the front bumper
Vehicle: 2010 NGV
Post Posted: Wed Aug 22, 2018 6:10 pm
Yeah I removed mine a while back. One of the first mods I did as I knew it would rip off. I used trusty old zipties to reconnect the wheel wells to the bumper, just drilled a hole to thread it through. Although I should admit that when I hit some mud, the drivers side well came loose and then a fairly significant section was melted away by rubbing against the tyre. I just zipped it up again. It is good enough for me, but you might want to try a more elegant solution.
Post Posted: Thu Aug 23, 2018 2:23 pm
ace - i've got some aluminium "L" channel - might fab some brackets just to tie it together
other option was to take to it with a hot-saw to cut the lip down to 10mm high etc
Users browsing this forum: Google Adsense [Bot] and 247 guests
