It is currently Thu Oct 08, 2026 10:23 pm
Vehicle: lj50
Post Posted: Sun Aug 26, 2018 7:15 am
Hi all,
Chasing an oversize piston and ring set for an LJ 50. Can anyone point me in the right direction?
Actually doing a full rebuild so any info on sourcing parts for the little 2 banger would be helpful
Cheers, Boofdog
Vehicle: 1993 Suzuki Sierra 1.3 SWB
Post Posted: Wed Aug 29, 2018 7:12 pm
Boofdog,
I had an LJ50 in the 70's, I replaced the pistons with the pistons from the 3 cyl 2 stroke van, not sure of the engine designation but you should be able to source that online, I had to have the engine bored to accept the 2 stroke van pistons as they were a fair bit larger and from memory it upped the capacity to 650 - 660 cc, no other modifications were done to the engine the increase in performance was quite noticeable. I will look online and see if I can find any other info for you. regards barbender.
Vehicle: lj50
Post Posted: Thu Aug 30, 2018 12:44 pm
Cheers Barbender,
Have found a set of standard pistons and rings, but definitely need a re bore, so will have to go oversize. I thought the old 2 stroke van had the same lj50 motor. Someone told me they used to do three oversizes, .5mm, .75mm, 1mm
I did happen to find one 1mm over piston, but really need a full set and rings as well.
Vehicle: sc100 se416 mightyboy
Post Posted: Thu Aug 30, 2018 9:54 pm
I have plenty of used engine parts for the 2 stroke, but nothing aftermarket like oversized pistons etc.
Why make your Suzuki like a Vitara, Just get one.
Post Posted: Fri Aug 31, 2018 11:23 am
There was a thread started by tanshi, post date Sunday October 24th, 2010 at 7:17 am. similar to what you want, regarding the Suzuki Carry engine, I am looking for an old 4x4 mag that had a lot of info on this when I rebuilt my LJ50, if I can find it I will scan it and email it to you. regards, barbender
Vehicle: lj50
Post Posted: Wed Sep 05, 2018 8:00 pm
Cheers barbender,
Any info is helpful!! I am talking to a bloke who may be able to sleeve the damaged bore so that the standard size pistons can be used.
Post Posted: Fri Sep 07, 2018 1:12 pm
you can buy them new on EBAY
Vehicle: lj50
Post Posted: Fri Sep 07, 2018 3:31 pm
Yes tanshi, only in standard size. Was just seeing if anyone knew where to get OVERSIZE. All good I'll get there!
Vehicle: 1973 lj50 fully restored
Post Posted: Mon Sep 10, 2018 8:03 pm
Full engine rebuild kits for all Suzuki models with several os piston sizes are available from 4x4 parts on e bay good quality and price have used them several times for Suzy parts new owners but still good service.
Post Posted: Thu Sep 13, 2018 10:22 am
you can get OS size ones on ebay bud
Vehicle: lj50
Post Posted: Thu Sep 27, 2018 10:35 am
Cheers Guys,
I have got hold of a set!!
Users browsing this forum: No registered users and 157 guests
