It is currently Tue Oct 06, 2026 12:15 pm
Vehicle: GV 3d 2014
Post Posted: Sat Sep 15, 2018 4:03 pm
Grand Vitara, year 2014, 3 door. The remote buttons to unlock and lock the doors on both keys need to be pressed a number of times, hoping one of the times it's pressed will work. New batteries in both keys. I've read other topics which suggest a fault with the door sensing switches can be the cause of this. The inside light always works ok with the door operation.
Thanks for any suggestions?
Post Posted: Sun Sep 16, 2018 3:36 am
Do the power locks work properly from inside the vehicle (driver's door controls) - if they do that would eliminate door sense switches as a potential cause of the problem.
Vehicle: GV 3d 2014
Post Posted: Sun Sep 16, 2018 11:27 am
Yes, they work ok.
Post Posted: Mon Sep 17, 2018 4:57 am
I'd say either the remotes or the receiver is defective - I'm betting on the remotes.
Vehicle: GV 3d 2014
Post Posted: Mon Sep 17, 2018 8:46 am
It would be odd for both keys to have the exact same fault.
Post Posted: Mon Sep 17, 2018 10:34 pm
You might think so, but, consider this - which button on the key gets pressed the most? Is it the same button on each key? Do the buttons wear out?
Vehicle: GV 3d 2014
Post Posted: Tue Sep 18, 2018 2:27 pm
The buttons that get pressed the most are the two on the key that's in use. The other key is usually left at home as a spare.
Vehicle: Swift
Post Posted: Fri Oct 05, 2018 11:27 pm
feraltek wrote:
The buttons test link that get pressed the most are the two on the key that's in use. The other key is usually left at home as a spare.
Did u get to the bottom of this, Feraltek? Please tell me it's not the receiver. lol
Vehicle: GV 3d 2014
Post Posted: Sun Oct 07, 2018 6:05 pm
Thanks for following this up. I've been away on a few kayak trips. It was the "new" batteries I purchased on eBay.
Users browsing this forum: No registered users and 110 guests
