It is currently Tue Oct 06, 2026 1:06 pm
Vehicle: Sj70
Post Posted: Fri Oct 05, 2018 10:37 am
Hey all,
I need to upgrade my cooling system on the sierra. My radiator is stuffed and she is getting hot with the g16b under the bonnet. A few questions....
1. What raidiator should I buy: Stock radiator, or alloy radiator. They are around the same price, I see the benefits of the alloy, however I am nervous about electrolysis... what is your opinions, or experience, how to mount alloy?
2. Thermo controller setup. Currently i have a mechanical thermo controller, works great but the probe being pushed in between the inlet and the hose leaks. So, I have a threaded controller kit similar to: https://www.ebay.com.au/itm/THERMO-FAN- ... SwSlBY4LCb
And was planning on using a gauge sensor adapter similar to:
https://www.ebay.com.au/itm/38mm-Radiat ... SwhxBZt3Gj
However I have been told that because the sensor in this setup is earthed through the thread and because I will need to earth the adapter it will cause me electrolysis problems.
So, now I am nervous to do anything!!!!!
Help! 8O :shocked:
Post Posted: Fri Oct 05, 2018 3:01 pm
Stock radiator, vitara viscous hub fan from the G16b, Sierra shroud. Won’t overheat.
It’s most likely overheating because of the thermo fan.
Vehicle: Sj70
Post Posted: Sat Oct 06, 2018 1:26 pm
Such as: https://rover.ebay.com/rover/0/0/0?mpre ... 1045380421
Mitch
Post Posted: Sun Oct 07, 2018 5:33 pm
That'll do, but I dislike plastic tanked radiators with aluminium cores - They're fragile.
Personally, I'd find a stock copper radiator in better condition or get yours reconditioned, but I understand they're hard to find now. MUCH more robust and repairable than an aluminium cored radiator.
I'd still put the blame at the thermo before the radiator though.
Users browsing this forum: Google [Bot] and 109 guests
