Vehicle: 85 Drover tin top
Posted: Tue Oct 23, 2018 12:21 pm
Has anyone broken the gearstick pivot bolt then lost the broken bit in the gearbox? my son has fished around with a magnet but no joy. He also dropped the oil and tried fishing for it in the bottom , still nothing!
Posted: Tue Oct 23, 2018 3:31 pm
It could only be in the extension housing which is the bit bolted onto the rear of the gearbox case.
It’s around 8 12mm Bolts securing it and should be easy to remove although I can’t tell you if this would need to gearbox to be removed from the car or not.
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
Posted: Thu Oct 25, 2018 2:23 am
Happen to me. I got a thin bit of wire and poked around till I got it where I could see a bit of it. Tried a magnet, then got a cheap three fingered thing and out it came.
Users browsing this forum: No registered users and 234 guests
