http://auszookers.com/forum/
f10a carburator with feed back
http://auszookers.com/forum/viewtopic.php?f=5&t=55495
Author:  solac03 [ Thu Oct 25, 2018 12:26 am ]
Post subject:  f10a carburator with feed back
hi,
I was wondering if anyone knows how the feedback of f10a carburetor works and the vacuum lines?
Author:  sideways [ Thu Oct 25, 2018 9:04 am ]
Post subject:  Re: f10a carburator with feed back
What do you mean by feedback?
Vacuum lines depend on the year. Early ones only have a line from the charcoal cannister to the inlet manifold.
Later ones have vacuum advance which connects to a port on the carby.
Some later ones have EGR which is it's own massive clusterfuck of vacuum lines.
Author:  solac03 [ Fri Oct 26, 2018 10:43 pm ]
Well i am from the Philippines and recently I bought a used Suzuki carry it has and f10a engine in it. I don't know much about carbs, but i found that my carb has a electronic feedback. It has a oxygen sensor and a control unit connected to some sort of solenoid that seems to give air depending on o2 readings. My guess is it checks the exhaust output and lets air in the carb to control stoic. I suspect that the vacuum lines are not where they are suppose to be.
i managed to take photos of a local parts supplier parts manual and found that the part is named AIR BLEED CONTROL VALVE, unfortunately i can't make of where the vacuum hose go as my unit does not have an egr. and the carb has lots of lines that is not clearly described in the parts diagram. i have googled for hours and came out with nothing. from the parts catalog i found out that the body code is SK410. so maybe if anyone has a service manual maybe can check this out for me, regarding how this thing functions.
this is the control unit
Author:  solac03 [ Fri Oct 26, 2018 10:47 pm ]
hi,
I recently bought a suzuki carry with f10a engine. The carb has a feed back system it has an oxygen sensor a control unit and some sort of stepper motor. My guess is it checks the o2 readings then gives air to the carb to control stoic.
i managed to get some photos for a parts catalog from a local supplier.
i suspect that the hose are not where they are supposed to be.
