It is currently Thu Sep 24, 2026 1:53 pm
Vehicle: 2011 Jimny
Post Posted: Mon Feb 25, 2019 1:45 pm
Even though the M18 conversion is rather common, it seems that very few people actually do more than run it on the stock Jimny M13 ecu. I was hoping to start a slightly educated discussion on getting the M18 running correctly (ie. correct fuel trims, AFR's, Load etc).
I'm currently experimenting with the M13 and M18 parts to get the above figures as close as possible before i investment in a piggy back or stand alone ECU.
So far i'm having decent progress with the following:
M18 Block+Head
M18 Intake manifold
M18 Throttle Body
M13 ECU
M13 Exhaust (soon to change)
M13 injectors
M13 Intake piping, air filter and MAF sensor
I'm currently getting decent AFR's and fuel trims but i need to fix the engine load as it seems to be over reading the figures causing the ECU to go open loop to soon/frequently. I believe the engine load is incorrect due to more air being sucked through the original sized intake/MAF. My plan is to change the MAF reading by adding a resistor to the MAF's signal wire and allowing the ECU to TRIM the closed loop fueling to the correct AFRs but having the engine load be reduced to the reduced MAF reading.
The Jimny runs both MAF and MAP sensors and I'm assuming MAF is used to calculate load. Can anyone confirm this?
I'm also building a ECU data logger currently so i can get actual figures from the ECU and my wideband sensor, rather than just looking at the gauges while driving.
Feel free to chip in if you have any suggestions or experience.
2011 jimny, 30s, china locker, swift 1.5, pink playboy seat covers
Vehicle: 2011 Jimny
Post Posted: Wed Mar 13, 2019 11:21 am
Ive swapped the M13 injectors back to the M18 injectors. The fuel trims with the M13 injectors have been great but the afr has been leaning out too much under low RPM and high load. I prefer too rich over too lean. :D
I still haven't gotten around to trying to fool the ECU into reading a correct load, hopefully this weekend.
Vehicle: Vitara 1994
Post Posted: Wed Mar 13, 2019 1:28 pm
Should be an interesting thread
Post Posted: Thu Apr 11, 2019 9:04 pm
Any update on this? Looking forward to results
Vehicle: 2011 Jimny
Post Posted: Fri Apr 12, 2019 12:49 pm
I had problems with my obd2 adapter not working on the Jimny (even though it works on the wifes Swift) so I've ordered a different adapter which is meant to arrive today but UPS have informed me my house doesn't exist...
I also picked up a X90 on the cheap so I've been distracted with that.
Users browsing this forum: Google [Bot] and 151 guests
