Hey guys can’t find much info on this, looking for a full float rear kit to suit a SJ80 is it the same as the jimmy? Honestly just looking for something that I’ll be able to work on trackside (remove) if I bust an axle as I do a lot of driving solo.
No, Jimny is a different width. Sj80 is wider than SJ70, narrower than jimny. I’m not sure if the bearing and backing plate arrangement is the same as sj70, if so you could use an sJ70 kit and just have longer axles made n
Users browsing this forum: No registered users and 243 guests
