It is currently Sun Aug 30, 2026 7:25 pm
Vehicle: 87 Samurai
Post Posted: Mon May 06, 2019 1:13 am
Anyone installed a TK1 or Currie anti sway bar kit in their Samurai? Maybe made their own from an Izuzu Trooper 36" torsion bar.......or??
Yes, I know......an anti sway bar is not needed for oem samurai-length springs. I have Yj length springs, and am considering installing one. Like to see how you've installed one, or made your own from donor car parts.
https://store.tk1racing.com/ProductDeta ... ode=110-00
Pics?
Post Posted: Mon May 06, 2019 7:06 am
I’d be incredibly surprised if you need one, and if you do, it will require a very low rate- much lower than typical for these torsion bar types.
Which end did you envisage using it?
Vehicle: 87 Samurai
Post Posted: Wed May 08, 2019 2:22 am
My yj springs are pretty soft and flexy. I'll have bilstein 5125's valved 170 / 60 on the front and bilstein's valved 255 /70 on the rear.
I do have to use in-boarded shock mount for the rear, it sucks, I know, and in-boarding shocks does potentiate body roll. Hoping the the 255 / 70 shocks installed at a 41 deg angle [ the best I can do ] will help mitigate some body roll.
Been chatting with Tony, the owner of the TK1 Rockcrawler kit. Gave him my zuks specs and my expectations / needs for managing my samurai's body roll. He thot his Rockcrawler kit with 16" arm would provide the anti-sway that I need. It has the smallest diameter bar at .750".
Some pics of the modified Spidertrax bar I just completed. The rear shock angle WAS almost 50 degrees when spoa, it is now 41 degrees with the modded mount and spua.
Vehicle: 87 Samurai
Post Posted: Wed May 08, 2019 2:24 am
I'd put the TK1 kit on the front.
Vehicle: Vitara 1994
Post Posted: Wed May 08, 2019 4:46 am
Personally I wouldn’t run any swaybar kit on the samurai
Post Posted: Wed May 08, 2019 6:59 am
Based on your information It won’t be required.
Vehicle: 87 Samurai
Post Posted: Mon May 13, 2019 11:49 pm
Yeah, going to drive it for a while as is first, before spending the $$.
Users browsing this forum: Andygoodbloke and 81 guests
