Move the spring pads on the WT axles inboard- same as swapping WT axles into a 1.0 Sierra. Also consider your gearing will be noticeably taller- WT axles =3.7 ratio, maruti 4.1 ratio, you’ll also need a WT draglink. Not sure about driveshaft yokes.
Users browsing this forum: No registered users and 76 guests
