| Author |
Message |
rj308
Vehicle: 2017 Suzuki Jimny
 Posted: Sat Jul 13, 2019 11:21 pm |
Gentlemen, I have a question for those who may have done this. To install new kingpin bearings, is it possible to:
Remove the wheel, brake caliper, brake disk, tie rod end (and steering arm), vacuum hoses, ABS sensor, large swivel seals and then just remove the kingpins and pull out the hub/rotor/knuckle/axle shaft as a unit?
If this is possible, is it difficult getting the axle shaft splines lined up in the differential when you reinstall the unit?
Thanks in advance for info from those who have done it this way. RJ
BEE55T
Joined: Sun May 26, 2019 8:49 am Posts: 14 Location: The 'Gong
Vehicle: '99 Jimny for the Daughter
 Posted: Sun Jul 14, 2019 6:26 pm |
There is a good pdf on bigjimny.com. Google is your friend. Did ours recently. About 6hrs total. Do the inner axle seals while you're at it.
rj308
 Posted: Sun Jul 14, 2019 11:42 pm |
Yes Beest, I had already looked at that. I just do not see any reason that the hubs needed to be taken apart. I am looking for acknowledgment that it is possible to do it as I described it in my OP. Maybe I should just ask if it is at all difficult to re-insert the splines of the axles back into the differential when putting the axles back in. \ Thanks, RJ
BEE55T
 Posted: Wed Jul 17, 2019 6:49 pm |
sorry, yeah, no need to disassemble the wheel bearings/hub. The whole thing comes off as one item. Cv's and axles pretty simple to remove and replace.  This is an easy way to put the bearing cups in. They tend to jump around a fair bit. Enjoy the greasy fun.
rj308
 Posted: Mon Jul 22, 2019 9:31 pm |
Thanks Beest. Great photo. RJ
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Mon Jul 22, 2019 9:57 pm |
It takes 20 seconds to take the hub and circlip off. It’ll take you much longer than that to wrangle the whole thing back into place with the axle attached to the spindle.
rj308
 Posted: Tue Jul 23, 2019 9:17 pm |
Gwagensteve, thanks, that is the kind of info I am looking for. Does Susuki use a gasket on the hubs or just a sealant? RJ
Gwagensteve
 Posted: Wed Jul 24, 2019 6:50 am |
Sierras use a gasket under the hub cap to hub body. Hub body to bearing housing doesn’t have a gasket- it’s a highly loaded connection and clean metal-metal contact is critical. Just use a smear of RTV on that connection.
