Vehicle: 1988 8v swb vitara jlx
Posted: Sun Sep 29, 2019 1:58 pm
I have just changed my rear wheel bearings to remove excessive end float on the right hand side but with new bearings and everything tight the end float is still there . Any ideas as to why its still there
That rear axle is located by the axle bearing, so any movement is either between the inner & outer race of the bearing, or between the outer race of the bearing and the axle housing.
Users browsing this forum: BOOSTED_PLAYA, Google [Bot] and 244 guests
