| Author |
Message |
Wicksy69
Vehicle: Suzuki sierra
 Posted: Tue Apr 07, 2020 8:02 pm |
Hey guys, I have a chance to pick up a JX vitara donor car pretty cheap, currently doing the 1.6 conversion in my sierra atm, just wondering what could I use from the vitara? I know I could use the brakes for rear disc conversion, the power steering and such but what else? Would doing whole axle swaps be worth it? The cluster? Hell even the whole drive line swap over? Just looking for some advice. Tia.
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Tue Apr 07, 2020 8:14 pm |
If it's a lwb vitara the front brakes will be vented a good upgrade for the front of a seirra
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Tue Apr 07, 2020 8:50 pm |
JX vitara's don't have power steering unless they're 4 door
Joe
 Posted: Tue Apr 07, 2020 9:56 pm |
Gwagensteve wrote: JX vitara's don't have power steering unless they're 4 door Some swb jx's did have seen two with ps and factory ac.
Wicksy69
 Posted: Wed Apr 08, 2020 5:26 am |
Its a 4 door JX, 92 year model. So front brakes, anything else I should get off it? Are the rear brakes worth getting as well?
Gwagensteve
 Posted: Wed Apr 08, 2020 7:19 am |
You could swap the gearbox with the engine, this is very desirable if it's an auto, less so if it's manual but there are still advantages - the vitara manual is bigger and has a much bigger flywheel and clutch so is better suited to the torque of the 1.6. Swapping the manual will require a shortened jackshaft, gearbox mount modifications and the tunnel will need to be opened up.
It's not feasible or desirable to retain the Vitara transfer case.
Rear brakes are not compatible with the sierra axlehousing.
To use the Vitara rear axle it would need to be cut down to retain sierra axles.
I have used the cluster, steering column, and complete vitara wiring loom in my car, but I was starting with an early 1.0 litre so I had a steel dash (easier to modify) and a ratty wiring loom, I was also using an automatic donor so the wiring is more complex.
You could use the vitara front diff gears (you'd need to source another vitara front set to swap front and rear into your sierra) but they're 5.12 rather than 3.7/3.9 depending on your model of sierra so thats a big step and will result in high road revs.
Eddy
Joined: Wed Mar 05, 2008 10:30 pm Posts: 382 Location: Waikerie
 Posted: Wed Apr 08, 2020 8:37 am |
I would be interested in buying the headlight assemblies from you ...
Wicksy69
 Posted: Wed Apr 08, 2020 10:21 am |
Gwagensteve wrote: I have used the cluster, steering column, and complete vitara wiring loom in my car, but I was starting with an early 1.0 litre so I had a steel dash (easier to modify) and a ratty wiring loom, I was also using an automatic donor so the wiring is more complex.
You could use the vitara front diff gears (you'd need to source another vitara front set to swap front and rear into your sierra) but they're 5.12 rather than 3.7/3.9 depending on your model of sierra so thats a big step and will result in high road revs. I have the cluster out of the baleno donor car, is the vitara one better to use?
Wicksy69
 Posted: Wed Apr 08, 2020 10:22 am |
Eddy wrote: I would be interested in buying the headlight assemblies from you ... Don't have the car yet, where are you located?
Eddy
 Posted: Wed Apr 08, 2020 12:48 pm |
Wicksy69 wrote: Eddy wrote: I would be interested in buying the headlight assemblies from you ... Don't have the car yet, yep realize that Quote: where are you located? Waikerie SA
Wicksy69
 Posted: Wed Apr 08, 2020 5:49 pm |
Eddy wrote: Wicksy69 wrote: Eddy wrote: I would be interested in buying the headlight assemblies from you ... Don't have the car yet, yep realize that Quote: where are you located? Waikerie SA Car is in QLD, I can give you the Facebook link if you want to message the guy, if not much is usable for me I won't bother getting the whole thing.
Eddy
 Posted: Wed Apr 08, 2020 10:18 pm |
Wicksy69 wrote: Car is in QLD, I can give you the Facebook link if you want to message the guy, if not much is usable for me I won't bother getting the whole thing.
yeah that works for me. Thanks!
Wicksy69
 Posted: Thu Apr 09, 2020 11:07 pm |
