It is currently Sat Sep 26, 2026 3:24 am
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Dec 18, 2020 4:45 pm
Anyone got the Suzuki cruise control (vacuum actuator) fitted in their Jimny or anything else? A wiring diagram would be bloody helpful!!!!
I scored a unit out of Liana, part number on the control box 202-3226, but so far I can't get it to work (no wiring diagram of course but it appears not TOO complicated). Light comes on, but no actuator. Maybe the wiring to brake/clutch switches that's wrong.
I have actually swapped over the steering wheel and factory switches (with a little modification here and there). Got the pulse wire sorted from the speedo, and the actuator is fitted and setup in the engine bay.
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Post Posted: Thu Jan 14, 2021 7:34 pm
It's up and running!! Works well.
Users browsing this forum: No registered users and 94 guests
