It is currently Sun Nov 15, 2026 1:08 am
Vehicle: 1994 Suzuki Sierra g16b
Post Posted: Fri Feb 05, 2021 9:47 am
G day Legends,
Have a few issues with a Sierra I purchased last year for hunting.It has been fitted out with g16b motor and gearbox has under slung diffs and lockers.
The rear diff has been modified to centre with the out put shaft of transfer so obviously axles have been shortened and resplined to suit housing.
Problem I have is that it looks like original long axles have been shortened and resplined. Having lockers they are very soft and have twisted with the l,h shearing at diff.
Can anyone tell me if there is anyone in Aus that can respline and shorten axles or supply custom chrome moly ones as no one seems to want to help out.
i can purchase long field axles from states but would have to respline and shorten to suit modified length some where in Aus has anyone one got any constructive suggestions thanks in advance.
Vehicle: 1996 suzuki Sierra
Post Posted: Sat Feb 06, 2021 6:38 pm
It might just be a diff from another 4wd, do you have any photos of it?
Post Posted: Sat Feb 06, 2021 7:50 pm
defiantly suzuki housing with centred diff, Axles have been shortened and resplined pics IMG_3101.jpegIMG_3100.jpeg have already replaced bearing kits with sierra kits housing measure 1200 mm from flange to flange axles are 670mm long and 625 mm short
Post Posted: Sat Feb 06, 2021 7:52 pm
Post Posted: Sat Feb 06, 2021 7:54 pm
Post Posted: Sat Feb 06, 2021 8:16 pm
Sounds like a bit of a mess, maybe just put a vitara rear housing in it and regear the front axle to suit.
Post Posted: Sun Feb 07, 2021 8:39 am
This.
Far easier, and cheaper than working out what the previous owner did. Also makes obtaining spares a lot easier.
Post Posted: Sun Feb 07, 2021 11:19 am
Actually, it probably already has vitara ring and pinions in it, so there would be no need to regear the front.
Can you post a picture of the rear axlehousing? We might be able to work out what's been done.
Post Posted: Sun Feb 07, 2021 2:30 pm
Ok pics are attached it has Nitro crown wheel and pinion 8x43 5.38 gears.I recon it has had outer flanges welded off a Sierra but not sure about housing.
Post Posted: Sun Feb 07, 2021 6:17 pm
/Users/bigboofbarra/Documents/urear diff picsntitled folder
Users browsing this forum: No registered users and 59 guests
