Vehicle: 1994 sj413
Posted: Mon Feb 15, 2021 8:33 am
hi all, i recently purchased a 1984 sj413 (advertised as an sj50 but im not sure about that) i had to replace the o ring on the water inlet pipe and when putting it back on one of the nipples on the water block broke so i had to take the carby off to replace the nipple. upon trying to put it all back together i think i put the vacuum hoses on wrong, as it was running rough and not idling right when it was at temperature and stalling when the clutch was pushed in. i will attach some images of the way i have put the hoses on if someone could correct me or send me photos of where they should be. there are also 2 (i assume) water nipples running through the carby and was wondering what they are for.
Users browsing this forum: Google Adsense [Bot] and 77 guests
