It is currently Sat Nov 14, 2026 12:04 pm
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Feb 20, 2021 2:53 pm
I have replaced the axle oil seals (and the hub seals etc) about three times in two years on the front diff of my Jimny 2010.
The seal on the passengers side lasts a short time and then leaks again, so ruining the king pin bearings as it washes out the grease. I intend to have another try, this time removing the whole diff housing. I found when re-inserting the axle, that getting the axle spline to line up with the diff mating spline (with housing in the car) is a real PIA, and I suspect MIGHT damage the seal in the process.
Only other things I can see that may affect the sealing of the seal, is the axle sealing surface (it’s good), a bent axle or a worn spindle bush. So I will check the axle and have bought two bushes (item 5-7) and will replace as well.
Any other things I should be checking for?
Just a comment about looking up parts - mine is an SN413 but how do the 'version' numbers slot in (V6?) for Aussie Jimnys?
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Vehicle: Sj51t
Post Posted: Sat Feb 20, 2021 6:58 pm
I have had same issue, I think I might have got it this time using a suzuki seal, I was starting to think I had a bent front housing
Post Posted: Sat Feb 20, 2021 10:27 pm
Where are you looking up the parts? There should be provision for you to enter the VIN or chassis number, which should take you to the correct version.
Users browsing this forum: No registered users and 85 guests
