It is currently Sat Nov 14, 2026 4:48 pm
Post Posted: Tue May 25, 2021 3:22 pm
It starts on the 3rd go of 3second cranks. Sometimes revs drop down to 400 for a second befoe climbing up tp 900. I'll order a fuel filter. I wait till the fuel pump stops before I attemp tp start it. Only when cold, runs like a race car most of the rtime.
tzr
bye
Post Posted: Tue May 25, 2021 7:48 pm
Plugs clean ?
What fuel pump are you running ?
Post Posted: Wed May 26, 2021 2:24 am
I've only had the car a month. I've done new plugs and lead, + tapet cover gasket and plug tube seals.
bye
Post Posted: Wed May 26, 2021 5:12 am
What stopss the fuel running back into the tank ?
bye
Post Posted: Wed May 26, 2021 5:17 am
Trying to edit the year model, too few characters.
bye
Post Posted: Wed May 26, 2021 5:18 am
Well that didn't work, it's a '96.
bye
Post Posted: Wed May 26, 2021 9:44 pm
Possibly throttle body/tps
In my experience soley changing the tps isnt enough to fix fluctuating idle/high idle. Ive found it best to swap the unit/sensor as a whole from another motor
Post Posted: Sat May 29, 2021 6:47 am
Thanks,
bye
Post Posted: Mon May 31, 2021 3:12 pm
I thought I'd take the TPS off and give it a hit with throtle body spray. With just two bolts, I thought idiot proof, it's not.
After a lot of ajustment, I think I've got it back where it was, How is it fitted ?
bye
Post Posted: Tue Jun 01, 2021 4:32 pm
The TPSis still out a bit, I've got a hesitation at 2000rpm.
Do I just fiddle with it like a distributor till it's smooth ?
tar
bye
Post Posted: Fri Jun 04, 2021 5:06 pm
I got lucky, runs like a dream again.
bye
Post Posted: Fri Jun 04, 2021 8:43 pm
Hopefully it stays running ok
Normally it doesnt
Post Posted: Mon Jun 07, 2021 5:50 am
It's still hard to start. Apparently my buggered water pump could be the cause of this and itermittent idle issue. A guy a Bursons told me I should have checked the new plug gaps. I can't see anything wrong with the cavuum hoses, but I'll replace them too,
bye
Post Posted: Mon Jun 07, 2021 7:44 am
Water pump will have nothing to do with hard starting. A G16b will start just fine with every sensor unplugged and no water in it.
Problem is most likely ignition related.
Post Posted: Wed Jun 09, 2021 5:45 am
Good, I won't worry about the water pump. The Island is only 7K's long. I realise the TPS is on the way out, but I'll wait till fails. I'll set the sparks to a hackksaw blade, and that's me.
bye
Users browsing this forum: Google [Bot], seanzook06 and 73 guests
