It is currently Sat Nov 14, 2026 10:44 pm
Vehicle: Coily.
Post Posted: Fri Jul 16, 2021 7:10 am
Hi..the Dizzy seal is leaking again on our 98 Coily,it has been done twice by Mechanics(for Rego)in the 10 years we have had the car.
I will do it myself this time but was wondering what is the best sealant to use,i usually use Silastic Gasket on my other cars but not sure what the mechanics have used in the past....TIA.
Post Posted: Fri Jul 16, 2021 7:59 am
Its just a rubber o-ring from memory
Certainly wouldnt use silastic
Vehicle: Coily.
Post Posted: Fri Jul 16, 2021 8:19 am
Thanks for reply,whatever the Mechanics have done hasn't worked,i'll see if there's any goo there when i get it off.
Post Posted: Fri Jul 16, 2021 7:05 pm
Id wager the mechs just used a generic o ring.
If you want it to last maybe try a genuine part.
That being said if you dont drive the car often the seal will dry out and perish.
Its the same with rear mains, axle seals ect... you tend to change them more often when they sit idle than with daily use
Post Posted: Fri Jul 16, 2021 8:21 pm
Before you take that thing apart clean it thoroughly and determine exactly where the leak is - there is an O-ring where the distributor mount attaches to the head, an O-ring where the distributor slides into the mount, and a garter style seal inside the distributor.
Vehicle: Coily.
Post Posted: Sat Jul 17, 2021 9:23 am
fordem wrote:
,..... an O-ring where the distributor slides into the mount, and a garter style seal inside the distributor.
Thanks,i've forgotten about them,í'm sure they haven't been replaced,only the mount to the head.
Now to try and track down the part numbers.
Vehicle: Coily.
Post Posted: Thu Jul 22, 2021 9:35 am
One more enquiry,anyone know where to get a cap/rotor or complete dizzy for the Coily?
I've been told the early ones don't fit....TIA
Post Posted: Fri Jul 23, 2021 7:36 am
Suzistore
Vehicle: Coily.
Post Posted: Sun Jul 25, 2021 8:22 am
Thanks Rocky.
Users browsing this forum: No registered users and 73 guests
