Page 1 of 1
[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
muddytrail
Vehicle: lwb stockman
 Posted: Thu Jul 22, 2021 1:20 pm |
Would anyone have a link or have a wiring diagram for a JB32W or I’m guessig it’s the same a Sj80? I’ve purchased a half cut and using wiring loom in maruti ute, the Suzuki jimny is a 13bb.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Fri Jul 23, 2021 10:39 am |
Hang on a minute there, I need to unpack that.
Are you blending a complete JB32W wiring loom into an Maruti, but swapping in a G13BB?
Yes, you're correct a JB32W will be largely the same as an AU delivery SJ80. Expect to see more wiring though, for things like electric power steer, possibly TBi fuel injection and other JDM options.
muddytrail
 Posted: Fri Jul 23, 2021 9:28 pm |
I know it’s a bit of a mouthful lol, The maruti was converted to g13a and then I come across the half cut g13bb. I have removed the maruti dash and fitted a sj70 dash so I can have a vss fitted easier. The engine is running well through the ignition barrel and lights, wipers, horn all work but I’m having trouble with the dash cluster, if I turn the hazard lights on the fuel gauge goes up hence needing a better diagram.
Gwagensteve
 Posted: Sat Jul 24, 2021 8:34 am |
That's typically an earthing problem. Gauges need a very clean and stable supply to prevent them fluctuating with electrical load.
muddytrail
 Posted: Sat Jul 24, 2021 10:44 pm |
Ok thanks I’ll keep trying, What does the 1 single black wire earth, the one held on with a nut? (back of SJ70 cluster)
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 91 guests
