| Author |
Message |
chris77
Vehicle: sj413
 Posted: Sun Aug 29, 2021 3:34 pm |
Hello
Anyone able to take a couple of measurements for me of a stock sj410 or 413 . I am after track width , center to center of tyres and also the height of the engine crank center line to the ground ? One google website says the track width is 1210 , but I have not found anything for engine crank height .
The rules in NZ now have a ratio of engine height to track width and measuring up mine I only just comply , so I am wondering if a stock sj410 would even comply with the requirements . Mine is not factory anymore so making theoretical measurements is a little hard .
Off the top of my head I cant remember is a 410is narrower than a 413 , dont think so , so the measurements of a 413 would probably also work . I wonder how a LJ80 stacks up .
Thanks Chris
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Sun Aug 29, 2021 4:38 pm |
SJ410/413 are the same track width up until 1988, after that they widened them.
Early model is 1210mm and after 88 is 1300mm.
LJ80 is near enough the same track width (10-20mm narrower from memory) as early SJ but the engine is mounted a lot higher.
Dunno about crank heights.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Sun Aug 29, 2021 5:06 pm |
That cast iron f10 block is a fair bit heavier than a 1.3 also might be worth paying attention to
_________________ ...
sideways
 Posted: Sun Aug 29, 2021 5:19 pm |
MrRocky wrote: That cast iron f10 block is a fair bit heavier than a 1.3 also might be worth paying attention to Nope I've weighed them. Complete F10a was 4KG lighter than an G13ba. Same scale, same day. G13 was missing a few little things the F10a had like the hoses and fan but otherwise that's both with manifolds, carbies alternators ect. F10a might be cast iron block but it's a lot smaller.
MrRocky
 Posted: Sun Aug 29, 2021 7:48 pm |
Id have to disagree, ive lifted many of each. Even on paper the f10 comes in 20kg heavier
sideways
 Posted: Sun Aug 29, 2021 8:07 pm |
MrRocky wrote: Id have to disagree, ive lifted many of each. Even on paper the f10 comes in 20kg heavier Yeah I've lifted many of each too, difference is I've lifted them with a crane with a scale on it. An SJ40 is 810kg and the lightest SJ50 is 850kg.
MrRocky
 Posted: Sun Aug 29, 2021 8:51 pm |
Suzuki say your scales are 20kg out
sideways
 Posted: Sun Aug 29, 2021 9:24 pm |
MrRocky wrote: Suzuki say your scales are 20kg out Bullshit, prove it.
MrRocky
 Posted: Sun Aug 29, 2021 10:05 pm |
Haha i dont have to Every bit of data on the interwebs says f10a is 20kg heavier
sideways
 Posted: Sun Aug 29, 2021 10:13 pm |
MrRocky wrote: Haha i dont have to Every bit of data on the interwebs says f10a is 20kg heavier No it doesn't, just scroll up. In fact, your posts are the only thing on the internet saying it's 20kg heavier and we all know they're mostly bullshit.
MrRocky
 Posted: Mon Aug 30, 2021 8:26 am |
Now now thats not a nice way to speak to your newest neighbour. All the guys shipping f10a engines list them heavier than the g13's
sideways
 Posted: Mon Aug 30, 2021 9:03 am |
MrRocky wrote: Now now thats not a nice way to speak to your newest neighbour. All the guys shipping f10a engines list them heavier than the g13's No they don't, because they're not heavier. If they were you could provide an example but all you can provide is more bullshit. sideways wrote: F10a, complete with both manifolds, clutch, alternator, carby, oil ect.
82.05kg
G13ba, largely the same as above but the F10a had a bit more stuff on it like the fan, radiator hoses ect.
85.45kg
MrRocky
 Posted: Mon Aug 30, 2021 2:01 pm |
Haha you had better get busy you got 4702 posts to fact check. I still stand by my comment the f10a is heavier Change my mind
sideways
 Posted: Tue Aug 31, 2021 12:13 pm |
MrRocky wrote: Haha you had better get busy you got 4702 posts to fact check. I still stand by my comment the f10a is heavier Change my mind You can stand by your comment all you like, it's still wrong. You've never been one to put facts in the way of some trolling.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Tue Aug 31, 2021 12:36 pm |
MrRocky
 Posted: Tue Aug 31, 2021 8:36 pm |
Do your scales come with a calibration certificate lol The two previous weights quoted by other auszookers in the thread you posted your weights in seem a bit under also...
Boggomobile
Joined: Tue Oct 04, 2011 8:43 pm Posts: 640 Location: Northern NSW
 Posted: Tue Aug 31, 2021 9:44 pm |
Hi All, This is interesting and I am not going to weigh in with my opinion even though I have moved plenty of F10As and G13As along with a few conversions. Just wanted to suggest hanging one of each on either end of a SeeSaw and see what happens? If all else fails you can use the SeeSaw as a bridge and get over it!
_________________ COOL BANANAS!
