It is currently Mon Sep 21, 2026 5:44 pm
Vehicle: Suzuki jimny 2005
Post Posted: Thu Jul 14, 2022 3:35 pm
Hey guys,
As per title, I need to fill a jimny gearbox with oil. I drained the old oil out with the intention of filling it like I used to on a Sierra (remove gear lever and pour in).
I know there’s a bung in the side of it, but I can’t even see it. Is that the only way to fill it? Or is there a easier way?
Post Posted: Fri Jul 29, 2022 3:07 pm
I worked it out, so I thought I’d share in case it helps anybody else.
First of all the jimny is a vvti varient, which has the filler bung on the passenger side. I have a non vvti gearbox as well which has the filler on the drivers side, so I was looking on the wrong side initially.
After finding it the only way I could undo it was by holding the 10mm square bit with vice grips (also needed to put some shallow cuts into the bit for traction for the vice grips.
There might be an easier way to do this, but this is what I did.
https://pasteboard.co/7GOYovZkn1VS.jpg
https://pasteboard.co/acNEiYv72kDL.jpg
Vehicle: Coily.
Post Posted: Sat Jul 30, 2022 9:28 am
There should be a offset 10mm bar that will do the job.I'll throw a link in when i find it.
Users browsing this forum: No registered users and 195 guests
