I have a scenario where my 2004 jimny (auto, non-VVT) is currently stuck in limp mode. I've just completed an engine swap from the standard 1.3L to a 1.8L and had it running for around a month. However, I thought it would be a good idea to recondition the transmission to ensure it could keep up with the bigger engine. There was slight slipping in the gears, but otherwise no issues. After taking out the gearbox and getting it re-conned, the car has been stuck in limp mode ever since, only able to go into 2nd gear and reverse.
I've since taken it to Suzuki, where the scanner has basically comeback that all the sensors are working (2x speed sensors, inhibitor switch). We've since checked all the sensors and solenoids, and they're all working fine.
Users browsing this forum: Google [Bot] and 156 guests
