Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
rob_macca67
Joined: Fri Sep 28, 2007 11:30 pm Posts: 367 Location: Brisbane - Nthside
Vehicle: 1993 Suzuki Vitara 4dr Wgn
 Posted: Sat Oct 07, 2023 11:58 am |
Guys, I've got 2x SE416 93' model 5dr EFI Vitara's (G16B) and I'm having issues with the Tachometers in both. In one the Tacho doesn't work and in the other one the Tacho is not reading correctly.
I'm after some info on how these Tachos work (where do they get the signal from) and what things should I look at as possible causes & fixes?
thanks in advance
_________________ '93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2658 Location: Georgetown, Guyana
 Posted: Sat Oct 07, 2023 10:27 pm |
They get a feed from the ignition coil negative terminal via a noise suppressor. I've attached a snip from the wiring diagram, the brown wire (labelled br) is the feed, I'd say there's a high probability the actual tach is the problem, I've been told there are electrolytic capacitors in there that can dry out as they age. Attachment: vit-tach.JPG
rob_macca67
 Posted: Sun Oct 08, 2023 12:47 pm |
fordem wrote: They get a feed from the ignition coil negative terminal via a noise suppressor. I've attached a snip from the wiring diagram, the brown wire (labelled br) is the feed, I'd say there's a high probability the actual tach is the problem, I've been told there are electrolytic capacitors in there that can dry out as they age. Attachment: vit-tach.JPG Thanks for that.... so if that is the case, then its either another instrument Dash or wire in a separate Tacho? Quote: I've been told there are electrolytic capacitors in there that can dry out as they age. I wonder if u can open it all up and try resoldering those dry joints?
rob_macca67
 Posted: Sun Oct 08, 2023 3:07 pm |
Also... does anyone know where I can get the electronic version of the Electrical Diagrams & Service Manual for the SE416 Vitaras?
fordem
 Posted: Sun Oct 08, 2023 9:58 pm |
rob_macca67
 Posted: Mon Oct 09, 2023 7:42 am |
fordem wrote: Quote: Quote: I've been told there are electrolytic capacitors in there that can dry out as they age. I wonder if u can open it all up and try resoldering those dry joints? They are not "dry joints", they are "dried out" capacitors, and yes, they can be replaced, have a look at the first link below https://www.suzuki-forums.com/threads/t ... st-1644075You can download the manuals from ... http://www.rhinoman.org/manuals/vitara/vit_manuals.htmlThanks for that... much appreciated
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 61 guests
