Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Pezooki
Joined: Wed Apr 15, 2009 11:30 pm Posts: 115 Location: SE Melbourne
Vehicle: 91 Sierra SJ70
 Posted: Mon May 05, 2025 8:59 pm |
Hi all,
I need to replace my rear diff center and I have a box of random SJ70 diff parts, a mix of front and rear centers/gears/crownwheels etc from SJ70's... I might have enough bits to make a complete rear diff center out of the parts I have. However, I have only one main housing, and I don't remember where it came from. lol. ... I have 2 questions:
1 - are the main housings identical between front and rear on the SJ70?
2 - I seem to have only one pinion gear here, which is installed in the one main housing I have. Is this pinion gear the same across 3.7 and 3.9 ratio diffs? I can't remember where this housing came from, so it could be either I guess.
(FYI - I know about the different 2 and 4 pin internals, that's all good, I have a 4 pin one here I would use, and I believe I have the correct 26 spline side gears for the rear too...)
_________________ 91 Sierra soft-top.
fordem
 Posted: Mon May 05, 2025 11:32 pm |
Ideally pinion gears should never be separated from their crown wheels.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Tue May 06, 2025 11:11 am |
1)Yes 2)No
And what Fordem said.
Pezooki
 Posted: Tue May 06, 2025 11:59 am |
Thanks for the info. I know it's not ideal but if I have all the parts here I'll do it anyway.  There's also a chance that the entire matching assembly is there, but as there's a few random 3.9 parts parts in the box too, it's a bit of a mystery. Cheers.
Gwagensteve
 Posted: Wed May 07, 2025 7:47 am |
Pinion depth is going to be issue. I’d be surprised if you bed up with an acceptable setup.
Pezooki
 Posted: Wed May 07, 2025 7:56 am |
I'll let you know how it goes. There is a reasonable chance there is a matching pair amongst this box of parts.
Pezooki
 Posted: Wed May 21, 2025 5:15 pm |
Great success! I threw a rear diff center together from all the parts using my best guess, to match things up to their original configuration. I gave the center to my diff guy to setup and he was happy, it setup perfectly and I now have the diff I needed  . Now, if I can find some standard height leaf springs I will be ready for RWC... Finding these is proving to be a PITA. Cheers guys.
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: Google [Bot], seanzook06 and 79 guests
