It is currently Thu Jul 23, 2026 10:04 pm
Post Posted: Fri Jul 31, 2009 4:45 pm
my 4wd stick is stuck in neutral and won't budge.. tried everything I can think of but it's not moving..
anyone know how I could fix that??
Post Posted: Fri Jul 31, 2009 4:50 pm
buy a vitara :lol:
Vehicle: lj81 stockman
Post Posted: Fri Jul 31, 2009 4:54 pm
get a new one.is there oil in it my mates did this and there was no oil in it
the wobble rocks
Post Posted: Fri Jul 31, 2009 4:56 pm
happens when the selectors get stuck between gears. very very common in a sierra.
Post Posted: Fri Jul 31, 2009 4:57 pm
were do I check for the oil??
Post Posted: Fri Jul 31, 2009 4:59 pm
So how bout someone helping a guy out, (presuming you are a guy of course)How do you fix it???? Can you fix it without removing transfer from the car?
Post Posted: Fri Jul 31, 2009 5:02 pm
Is it deffinitly stuck in neutral? ie put your gearbox in neutral and can you roll the car. If not. put the stick out of the transfer and use a long screwdriver to manipulate the selector rods to get them in the right place.
Post Posted: Fri Jul 31, 2009 5:13 pm
i have had this happen many times before. pull the stick out of the transfer case and then put it back in, in the correct position. there should be a bush in there and it prob needs to be replaced. A mate had the same problem few weeks back, replaced the bush and it hasn't missed a beat.
Post Posted: Fri Jul 31, 2009 5:17 pm
Yep just a $5.00 bush mate.
Remove the steel spring around the rubber seal at the bottom of the stick and remove the rubber seal. (it slides up)
Get 2 screw drivers and pushdown and twist around (can't remember which way) and this will pop up. Then you can remove the stick.
Replace bush (easy, then fitting is the reverse.
Hope this helps
Post Posted: Fri Jul 31, 2009 8:01 pm
anyway to aviod this happening in the future?
Post Posted: Fri Jul 31, 2009 8:12 pm
slow gear changes, and / or a replacment bush
Post Posted: Fri Jul 31, 2009 9:19 pm
Replace the bush.. Mine did exactly the same thing..
Post Posted: Fri Jul 31, 2009 9:58 pm
Sorry a blonde has to say it
"Don't drive it"
Post Posted: Fri Jul 31, 2009 11:13 pm
mine use to do the same thing, this is before i had internet and this forum.
exclusive jap imports told me i had to buy a new box and cost me over $1000 to get done. and my speedo didnt even work right after. as you can imagine i was not happy when i found out later i all i had to replace the bush.
BUT yes take the rubber boot off the gear stick and have a look. its REALLY simple, i think all i needed was 2 screwdrivers or something like that.
Download Sets @ http://www.johnpaul.3leggedcat.net
Post Posted: Mon Aug 03, 2009 12:40 am
Hope this helps
Well Annoying after seeing two of the same issue threads mine did the same while 4wd'ing out today..
Stuck in Neutral...
So ive done
But I cannot for the life of my get that next cap thing to push down and twist..
Ive stuck two drivers in there, get it to drop in depth but then just cant get any purchase to twist it left or right?
Any tips for me?
Gonna have to be tomoza now as run out of light!
Post Posted: Mon Aug 03, 2009 12:44 am
Wear rubber gloves, no kidding. Or if you have an old grinder spanner you could modify..
Post Posted: Mon Aug 03, 2009 12:56 am
haha - Rubber gloves for ???
Post Posted: Mon Aug 03, 2009 3:36 am
greasy maybe, they can be a prick of thing to do, but push the mother down and turn :)
Post Posted: Mon Aug 03, 2009 5:05 am
Going to try in the morning..
Might try and fashion something out of a coat hanger..
Post Posted: Mon Aug 03, 2009 10:08 pm
Christ boys. Get under the car, Push down n twist.. took two seconds..
Wish I had of tried that the first time..
anyhow..
I cant figure out where or what im guiding in next?
Can someone shed any light on what im looking at??
Post Posted: Mon Aug 03, 2009 10:10 pm
Pic now correct
Vehicle: Zookless
Post Posted: Mon Aug 03, 2009 10:22 pm
All you have to do is move one of the bars "North or South" so that you see a "square hole" between them. That is what the shifter drops into.
Post Posted: Mon Aug 03, 2009 10:36 pm
Done..
She is pretty muddy inside mind..
Might drop the oil and and add some treatment..
Can you use 100% treatment for the t/case?
Fill from top?
Users browsing this forum: Google [Bot] and 359 guests
