It is currently Thu Jun 04, 2026 9:20 pm
Vehicle: 1995 Vitara V6 SV620-3
Post Posted: Fri Nov 22, 2024 3:18 am
Gday all, i am currently in possession of a 95 Vitara SV620 (SV620-3 specifically idk if it helps). The problem i currently have with it is that the input shaft bearing has grenaded sending shite all through the gearbox (Photos Attached) and i don't have the time, money or resources to fix it myself or get it reconditioned by a gearbox place, however i was able to find a gearbox from a scrap 96 SV420G/D (J20A) Vitara. From previous research i had come across, i found that the MT gearboxes through the different range of Vitara's have pretty much the same gear ratios/ ever so slightly different ones. here's the list i had down for the SV620 Gears:
Gear ratios: SV620 MT (Does anyone have the list of gear ratios for some of the Vitara variants? Preferably MT transmissions for the SE416, SV420D, SV420G, SV620)
- Gearbox
(1st) 3.928:1
(2nd) 2.333
(3rd) 1.451
(4th)1.000
(5th) 0.851
(R) 3.466
- Transfer case
Low - 1.186:1
High – 1.00:1
- Differentials
4.625:1
My thought process was because the SV gearboxes are so similar, that what i would do is replace the bellhousing on the SV420 with the one off of my V6 as the diagrams show that they are the same mounting pattern, and place the new gearbox in. however there have been several contradictions from sites when i was doing my research, heres what i found.
- SV420D Vitara (2WD) had the RF 2.0 diesel engine and was sold to European country's (and other select countrys)
- SV420G Vitara (4WD) had the J20A Petrol Engine and was sold everywhere else
- (Irrelevant but cool) the SV620 had 3 different sub variants (SV620, SV620-2, SV620-3) all corresponded to the different levels of trim available depending on the sales region
the big difference between the SV Variants is the MT Gearboxes, with the SV420D being 2WD unlike the others it had a completely different gearbox to the others which was my biggest concern when researching. If you are familiar with the website PartSouq (https://partsouq.com/en) you can insert the vin number and it tells you the exact variant of the car model that is copied in. and in my case it showed up with the donor box being from an SV420D, Even though it was sold with the J20A engine and had 4WD. so i am unsure if it is a Discrepansy in their system showing the car as D instead of G or if there will be the compatibility issue. However through the wonders of Tiktok i was able to get ahold of someone who had photos of the gearbox attached to the J20A that Sold in Aus, so im pretty sure that it is the right one as the Transfer looks the same and the Bellhousing bolt pattern/face looks the same too.
So tomorrow im going down to the wreckers to get the gearbox which has some good safety nets for it. Those being its coming off a 1996 3dr Vitara that had a cooked engine(J20A) and only had 220,000ks on the clock, it has a 3 month moneyback/Repair warranty, and has been inspected by the mechanics at the wreckers and seems to be fine, all for $700. so when i there im going to verify that my bellhousing fits on the Gearbox face.
If anyone has information on gear ratio lists/knowledge/advice, please let me know.
Cheers all
NOTE: the photo size of the files are too big to attach, i tried :(
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Sun Feb 15, 2026 10:15 pm
Bringing back an old Post...
I've search the web for the manual transmission ratios for the following (see below) and I cannot seem to find proper figures. The early SWB/LWB vitaras had a different 5spd from what I've been told but I cannot verify this on the web... can someone point me to a website where I can find all this info?
SE416 (SWB) - I believe 5th gear ratio is different (shorter) to the LWB?
SE416 (LWB) - I believe 5th gear ratio is different (taller) to the SWB?
SQ416 (SWB) - Cannot seem to locate ratios for this model
thanks in advance...
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Mon Feb 16, 2026 10:41 am
The difference in SE416 Vitara gearboxes in Australia is G16a (carbureted 8v) vs G16b (EFI 16v).
G16a has the 0.864 5th
G16b has the 0.794 5th
So all LWBs have the taller 5th and only early SWBs up to 1994 have the shorter 5th.
The ratios might not sound very different but that's a 300rpm difference at 110. (3444RPM@110 vs 3747)
SQ416 has the same ratios as G16b Vitara.
Now that a lot of the websites with good technical information are gone.. The best way I've found to source gear ratios is to search ebay for brochures. Just make sure you're getting the ones for your market.
Post Posted: Mon Feb 16, 2026 11:51 am
Thanks heaps for that, very much appreciated…
Do u know if a SQ416 gearbox be used in a 1993 LWB 5spd EFI Vitara Wgn?
I’ve been told the SQ416 GB input shaft is longer than the SE416 input shaft… is this correct?
Post Posted: Mon Feb 16, 2026 12:16 pm
No idea idea on that one mate, let us know if you find out.
Users browsing this forum: Google [Bot] and 27 guests
