I would be purchasing the standard heater hose and cutting it slightly longer than the one which came out as the shape will happen over time, if cut slightly longer it will allow for bends and if you need to cut an end, etc
It is available from the likes of Repco, or super cheap, and is very commonly available and will cost a hell of a lot less than a custom one out of India which is the other option.
The heater inlet hose has a very sharp kink in it and if using generic hose it will need to be quite long to make the bend. I’d recommend a genuine hose for that location.
Users browsing this forum: Google [Bot] and 137 guests
