As apart of keeping things in good working condition, plus when getting the rear diff done the workers put down potential work to consider being a the pinion bearing on the front diff (the back just cost me ($2350 NZ) and universal joints.
Are the universal joints all the same for every shaft? For example are the shafts between the gear box and the transfer case the same as the Universal joints from the rear diff and front diff?
Does anyone have a list of the bearings, or even seiko part numbers so I can go in and get exactly whet is needed rather than taking every shaft into the bearing shop
Users browsing this forum: No registered users and 113 guests
