Joined: Wed Apr 15, 2009 11:30 pm Posts: 111 Location: SE Melbourne
Vehicle: 91 Sierra soft-top
Posted: Sun Jun 07, 2026 4:00 pm
Hi all,
Are Narrow track and Wide track leaf springs the same, and interchangeable between NT and WT?
I have a 91 SWB WT Sierra and I need standard height (stock) leafs for RWC, (and also because it is unnecessarily high). I have found a set of NT springs available and I need to know if they will fit my WT?
Hmm. LWB rears are slightly shorter but I can’t confirm if it’s only the traybacks that use a shorter spring or all LWB. They fit, shackle angle will be slightly steeper that’s all. It’s only a few mm.
Posted: Tue Jun 09, 2026 4:57 pm
Ok thanks again. I'll keep hunting for SWB springs - if anyone here has a set of standard height leaf springs available, (SE Melb preferred) please let me know!
Users browsing this forum: Google [Bot] and 150 guests
