It is currently Thu Sep 03, 2026 4:34 am
Vehicle: Suzuki Sierra sj40 1981 model
Post Posted: Mon Jul 27, 2026 8:20 pm
I have a suzuki sierra sj40, 1981 model. It starts and idles ok but needs full choke to take off. Needs full choke on the slightest inclines and even then, at times, I have to put it into 4wd to make it up the hill. Suggestions anyone?
Vehicle: 86 SJ413 31's 1.6
Post Posted: Fri Jul 31, 2026 10:59 am
It might be a blocked jet, one does low revs and theres another one than lets fuel in when you put the foot down
Vehicle: LJ50 , LJ80Q-II
Post Posted: Wed Aug 05, 2026 9:38 am
sJ40 is F10a and side draft carb. Check the float bowel window , fuel should be at the level line . FSM explains how to set this . Check for air leaks with engine start selective spraying on parts of carb while running, if you have an air leak engine should surge . These are knowen for air leaks around the throttle butterfly . If this all checks out and timing / idle etc are set correct then most likely you have an internal carb problem , ie blocked jets / emulsifier leak etc and you prob need a rebuild of the carb. Not hard to do but be wary there are multiple variants of the F10 carb when looking for rebuild kits
Users browsing this forum: No registered users and 125 guests
