It is currently Thu Nov 19, 2026 4:56 pm
Post Posted: Thu Jan 04, 2007 12:10 am
on my wt, it turns further one way then the other, is there any common reasons for this?
Also when the tyres grab a bank or rise they will pull and start to climb, the steering wheel doesn't move, is this normal?
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Vehicle: 1994 Hard Top Sierra
Post Posted: Thu Jan 04, 2007 12:11 am
its a sierra mate it fairly normal
Jason
Navigator for Team Casper
Post Posted: Thu Jan 04, 2007 12:13 am
yep, steering is cause when you lift it the pitman arm is off centre
adjustable draglink will fix it (illegal and exxy)
the tyres grabbing are due to the scrub radius being stuffed up by the different offset of the rims hefty stabiliser will help, power steer will cure
other words, everything that helps in one way makes something else worse
Post Posted: Thu Jan 04, 2007 12:28 am
i see.
when i put the 1.6 in, i might go pull the p/s off the vitara.
or just get a decent damper
Users browsing this forum: Google [Bot] and 42 guests
