It is currently Sat Nov 14, 2026 3:38 pm
Post Posted: Wed Jan 10, 2007 10:19 am
Was having a play on a bit of a hill last night just mucking around, and now my car is idling like crap. It still runs smooth and no flat spots but the idle is rear low and all over the place Thinking maybe some crap in the fuel filter or carby? Or idle screw has turned a little (unlikely)
Any help appreciated
'85 Sierra SWB with Fibreglass hard top
30 inch M
Post Posted: Wed Jan 10, 2007 1:03 pm
Make sure one of the small hoses under the carb area has not come off. This happens to Casper at times but not going up hills.
Post Posted: Wed Jan 10, 2007 1:20 pm
if the idle was crap but consistent I would say dirt has got somewhere but like Bruce says it sounds like a vac hose is loose and as whatever its attached to activates it causes an air leak
grab some carb cleaner and spray it round the carby with it idleing, the idle will pick up or stall when you spray near the loose hose normally
another trick is to swap 2 and 3 plug leads, pop the top on the airfilter and give it a few good revs, normally shifts any stuck dirt :)
Post Posted: Wed Jan 10, 2007 5:14 pm
Fixed. The idle screw must have turned itself down somehow :S
I'm gunna give the carby a clean tonight too though. Thanks for the help once again guys. My zook is always having lots of little problems
30 inch M
Post Posted: Thu Jan 11, 2007 10:15 am
maybe not fixed... It sometimes comes right, then you give it a rev and ya get crappy idle again! I'm just gunna to take it to my mate to fix and give it a decent tune
30 inch M
Post Posted: Thu Jan 11, 2007 11:47 pm
Does it sound as if its idling on 3 cylinders? Mine does the same thing, and Ive been informed that it is a sticky valve.
We have put some unstickyvalve gunk in, but so far hasnt done much.
http://4x4onlines.iforumer.com/index.php?mforum=4x
Post Posted: Tue Jan 16, 2007 4:10 pm
Mine does this just take the air cleaner off and give it a rev and put your hand over the carby! Till the engine nearlly stops! Your hand will be covered in crap but your carb will not not have any crap in it!
back in a built sierra!
Vehicle: 75 Cruiser
Post Posted: Fri Mar 23, 2007 11:21 pm
bah, i was about to make a new post about the same thing here but then found this.
my motor was running fine and smooth on reving and idle a couple weeks ago, but now it's rough when running and doesn't idle.
I guess i'll get some carby cleaner tomorrow :roll:
Users browsing this forum: No registered users and 70 guests
