It is currently Fri Oct 09, 2026 11:05 am
Post Posted: Sat Aug 29, 2009 2:52 am
I dunno much about carbs so you will have to go easy on me.
The carb was empty, inline filter was empty too so put a bit of juice in the tank then got the girl to turn the key while i sprayed a bit of start ya bastrd down its throat, after a bit we could start it without the spray but it wouldnt idle. (bearing in mind there is no choke cable) after fiddling with the choke i could get it to rev up and slow right down, shut it off and left it for a while and tried it again now all it does whenever i turn the key is it goes off its tits and playing with the choke does nothing. what did i do? and what can i do to fix it?
Vehicle: LJ20 LJ50
Post Posted: Sat Aug 29, 2009 4:58 pm
Probably you missus since you left her in the car for so long, she is a little pissed off and is keeping her foot hard on the accelerator
or maybe the accelator cable is jammed.
Camels have nice toes
Post Posted: Sat Aug 29, 2009 6:27 pm
hahaha, no i would have heard the complaining if i left her in there. it does it even when there is no throttle
Post Posted: Mon Sep 07, 2009 10:31 pm
mabe pull it down and clean the jets might be sticking open
83 LWB,5" lift, rear locker,31's,custom bar work,
Post Posted: Mon Sep 07, 2009 11:23 pm
In the carby, not ya misses :D
Users browsing this forum: No registered users and 210 guests
