http://auszookers.com/forum/
coily front wheel bearings
http://auszookers.com/forum/viewtopic.php?f=5&t=6346
Page 1 of 3
Author:  bigrig91 [ Mon Aug 31, 2009 10:32 pm ]
Post subject:  coily front wheel bearings
i have had new front wheel bearings put in my coily twice now and they havent lasted a month at the latest whats going on.? Is it just coilys being shit? how can i stop this happening again. i didnt even go wheeling this time and they are flogged out. i havent taken it apart and looked at it yet but there is alot of play in the wheel...
cheers
Author:  steak_knife [ Mon Aug 31, 2009 11:17 pm ]
Post subject:  Re: coily front wheel bearings
Did you pay some one to fit them??
If you did , take it back.
If you fitted em, what grease did you use & how tight did you do em up??
Author:  bigrig91 [ Mon Aug 31, 2009 11:21 pm ]
yeh both times. they will just say the bearings failed and make me pay for labour again :(
Author:  31zook [ Mon Aug 31, 2009 11:26 pm ]
I do mine up to 75NM then off 1/4 turn then back on 10NM. I use high pressure grease from repco and it works great... 50kms just warm to touch, no play, and spins well...
Author:  steak_knife [ Mon Aug 31, 2009 11:31 pm ]
That`s BS. 1 month is appalling.
Thay are pretty straight forward to fit, should be a thread on it in here somewhere.
sound to me that thay`ve over tightened them or used the wrong grease.
Author:  bigrig91 [ Mon Aug 31, 2009 11:35 pm ]
yeh i did the back two the other day was pretty easy. if i re do them and it happens again im screwed...
Author:  steak_knife [ Mon Aug 31, 2009 11:38 pm ]
Front`s are easier! Y u screwed??
Author:  bigrig91 [ Mon Aug 31, 2009 11:40 pm ]
cause im a poor first year apprentice and bearing are pretty dear hahaha.
Author:  Trojan [ Mon Aug 31, 2009 11:50 pm ]
Coilys don't have a conventional hex nut, so there is a chance that they aren't doing them up properly as they don't have the proper tool.
Or
They could be sticking the wrong bering in. Not sure how different they are, but a coil model has different bearings to a leaf model.
Author:  bigrig91 [ Mon Aug 31, 2009 11:54 pm ]
yeh coilies are one big bearing and leafs are two skinnier ones. they are the right bearings i am sure but they just dont last. would they after a month wear in and just need adjusting??
Author:  Ridge [ Tue Sep 01, 2009 1:32 am ]
i should have a part number for the bearings, ill have a look for you and post up when i find them. are you using jap bearings, they are meant to be the best?
Author:  zookster666 [ Tue Sep 01, 2009 1:50 am ]
i would try adjusting them first if thats possible on a coily even crap bearings should last longer than a month
Author:  Trojan [ Tue Sep 01, 2009 2:05 am ]
even mine last longer then a month (just) and i get around on -50 10" rims and you'd expect nothing but for the bearings to be slaughtered.
Author:  bigrig91 [ Tue Sep 01, 2009 10:47 pm ]
yeh i bought jap bearings ridge forget what brand though. thats what i was thinking i only have small tyres its not like there is a heap of strain on them. cheers everyone for your help
Author:  bigrig91 [ Sat Sep 05, 2009 7:10 pm ]
just an update, havent taken it into the shop that fitted the bearings yet because apparently they are too busy.
pulled the wheel off today but only got as far as taking the hub off then got sidetracked. i remembered that when i picked the car up they said something about not having to grease the bearings.....what the. no grease = heaps of friction = heaps of heat = excessive wear doesnt it. ????? any ideas why they wouldnt have to grease them?
Author:  steak_knife [ Sat Sep 05, 2009 7:15 pm ]
I know Suzuki`s come greased, if thay had none in it when thay fitted them it would of made noise straight away, you wouldn`t of got 20km out of them!
Author:  brendan [ Sun Sep 06, 2009 1:17 am ]
wtf no grease my ass, what a bunch of dickheads. go to somwhere differnt and stay away from shotty looking shops
Author:  weaves [ Sun Sep 06, 2009 9:42 pm ]
if they are tapered roller bearings and there is not grease the mechanics at fault
if they have a sealed ball/double row/angular contact bearing it will come pre greased.
rule of thumb - if you cant see the rolling elements it doesnt need greasing. if you can it does.
weaves
Author:  Saam [ Sun Sep 06, 2009 10:33 pm ]
like i said last time this came up, the non genuine roller bearings never work, they are not designed properly, genuine, repack are the only options. i originally replaced mine, but put the originals back in repacked and tightened properly. the aftermarket ones stuffed my bearing hubs so i stole some off a jimny :)
Author:  WorldbyJimny [ Mon Sep 07, 2009 7:53 pm ]
Coily's run the same front bearings as Vitara. Yes they need grease! Is your diff housing not bent?? Massive wheels with massive offset??
Author:  paulv [ Thu Sep 10, 2009 6:46 am ]
What kinda aftermarket bearings are we talking about here Saam? NTN or Timken or some such? from a bearing shop like CBC or?
really surprised that there isn't a decent aftermarket bearing available, that is not as good or better than genuine.
Author:  Saam [ Thu Sep 10, 2009 2:56 pm ]
everyone has them listed as a roller bearing, i had a kit from cbc and they never tightened up properly and wore out my bearing hub, i beleive the coily is closer to the jimny than the vitara, i have jimny bearing hubs on my coily after mine where flogged out, do vitaras run a fat dual ball bearing ?
Author:  steak_knife [ Thu Sep 10, 2009 10:13 pm ]
Gv`s do, you can get them apart & greeze if you want, but you run the risk of damage`n the seal !
Author:  Saam [ Fri Sep 11, 2009 1:44 am ]
coily and jimny ones don't have a seal, and you can pull them apart aswell just got to try not to loose all the ballies
Author:  weaves [ Sat Sep 12, 2009 7:06 pm ]
suzuki don't manufacture bearings so 'aftermarket' should be the same if the numbers match up, i'm guessing you got an incorrect kit which was very similar, similar enough to use.
we get incorrect wheel bearing kits all the time. Some listings are incorrect but mostly its the customer telling us the wrong information. next time take a sample with you a and go from there. i beleive their supplier would have their kit listing wrong.
weaves
Author:  paulv [ Wed Sep 16, 2009 8:39 pm ]
weaves
Meaning take down the numbers from the actual bearings and seals that you pull out, rather than asking for a kit for 97 Sierra or whatever?
Author:  Saam [ Wed Sep 16, 2009 8:45 pm ]
yeah but he does not have an original bearing and even when i was cross referencing the part numbers i was getting a bearing which did not work, they where the right size but would never get tension, only the exact brand and part number seems to work
Author:  weaves [ Wed Sep 16, 2009 9:29 pm ]
paulv wrote:
weaves
like saam says there is not point taking down bearings that are wrong anyway, all you will confirm is they are supplying exactly what was wrong before.
i've just checked all my listings and they say (skf, cbc, wholesalers) NT, WT, coily and early jimny all run the same front wheel bearings
which is 2 x LM300849 cones & LM300811 cups
are you sure your hub or stub isn't damaged causing the rest to flog out quickly?
weaves
Author:  royce [ Wed Sep 16, 2009 9:49 pm ]
coilys and vita are a untiy setup, 1 big fat race you press in and 2 tapered bearings (well vit is tapered) that go in either side and you do the nut up FT cause they are machined to teh correct preload, nothing like a leafy at all
I got a cbc bearing in Jan that was wrong from teh start, will pull it out in the next few days to see what its like, I am guessing shit manufacture cause there is no way you can install it wrong short of not doing the nut up
Author:  Saam [ Wed Sep 16, 2009 10:25 pm ]
no coilies and jimny's have a ball bearing with a row of ball bearings inner and outer, the tapered bearing ones are the ones that fucked my bearing hubs.
and same as what your saying royce, you will find that on the tapered one that the bearing cup things touch in the middle before they tighten up and you never get load on the tapered rollers.
Page 1 of 3 All times are UTC + 9:30 hours
